elshawadfy
en respuesta a: Anonymous
Hi @Anonymous,
My understanding is: you want the geometry and some attributes in the leader legend to disappear, while some attributes remain..
I'm afraid my answer remains the same as I told you before in your thread..
Unfortunately when using more than one attribute in the block of the leader they all follow the layer of the last leader you created in the block.. regardless of the layers of other attributes.. i.e. when you turn ff the layer of that last attribute they all disappear, when you turn it an they all appear, when you turn on or off any other layer it doesn't matter..
so the geometry can be separated but all attributes follow the layer of the last attribute added to the block..
And as I said also, my workaround would be
1- To turn off the geometry, turn off the layer "ML_Geom"
2- to turn off the visibility of the unwanted attributes instead of their layer:
          - Use battman > select the block > select the attribute I don't want > edit > in the attribute tab > check invisible > close > synchronize > close battman > regen..
To disable any other attribute same thing, to enable it same ting just uncheck "invisible"..
2 files attached, one with all attributes one, one with geometry and both attributes within off (to turn off the geometry turn off the layer ML_Geom)
