1237 Vistas, 3 Respuestas
Automatic save: "X" minutes between saves (explanation)
Hi all, I am looking for clarification about the AutoCAD 2014 (and some previous versions) Automatic Save feature in the "File Safety Precautions" section of the "Open and Save" Tab in the Options menu (see screenshot)
The problem I'm having is that, if I start a drawing...do a bunch of work to it then wait an hour and force a crash of some sort...one that autocad cannot create a temp or anything from...im finding no "auto-saves" and also no "created backups after each save" (the checkbox option right below it)
my auto-save feature is currently checked, and set to 10 minutes between saves, the create backups check box is also checked.
That being said, I'm drawing the conclusion that the Automatic save feature is slightly misleading in its representation...
From what I've gathered this auto-save feature only starts to work after you manually save it the first time...so calling it an all out auto-save is slightly misrepresentation...since its a post-primary auto-save...
I am just curious if someone who is more familiar with this can please confirm or deny my assumptions and if they are incorrect, please correctly define how exactly and when this feature works, and when it starts to work.
Thanks for looking.
