1070 Vistas, 2 Respuestas
How to inverse break?
For example I have simple rectangle. (I am using AutoCAD 2016)
I need to get figure like on picture 1.
I press "break", choose first point, choose second point as on picture 2.
Unfortunately I get thing as on picture 3.
What am I doing wrong? And it's strange that if I do the same procedure to right edge I get what I need, but I need to do it with left edge (without using mirroring).
Alfred.NESWADBA
en respuesta a: Anonymous
a polyline has a direction (as you have drawn it), so it makes a difference if your polyline was drawn clockwise or counterclockwise.
In your case there is a better solution available (whenever you want to delete a complete segment of a polyline):
  • Hold the <CTRL> key and then click onto the segment you want to delete (this selects only that segment of the polyline)
  • Press <DEL> to erase it
  • (in that case the direction of the polyline is irrelevant)
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
en respuesta a: Alfred.NESWADBA
yeah! Both of your hints (about clockwise and about <CTRL>) work perfectly even if rectangle was inserted as rectangle (not drawn using polyline)
