12359 Vistas, 19 Respuestas
HELP ME - Invalid or incomplete DXF input -- drawing discarded.
Someone please help me. I have read all these threads on this site and beyond and nothing is opening my file.
Heres the info
Error in BLOCK_RECORD Table
Invalid symbol table record name: "" on line 21242.
Apparently I saved my file as a 2000 DXF file. So as I was working off a given DWG file, everytime I saved my drawing, It saved as a DXF .
Autocad crashed and now nothing will open my drawing.
 I have a deadline !!
Here's what I've done to fix it according to numerous threads on similar issues.
Open in Notepad and find the specfic line corresponding to the error message and fix the problem - DIDNT WORK
Rename the file with a .DWG- Didnt Work
Try opening the file in TrueView  - Didnt Work
Recovery, Audit, WBlock. - cant even attempt to do this because as soon as I hit enter or space after writing audit in the command line, it disappeers and becomes the normal Drawing 1 when you start a new drawing.  - Didnt Work
Sent the file to other people to try and open - Didnt Work
I have attached the file. please someone help me!
SEANT61
en respuesta a: Anonymous
This may only be a partial, but see if it helps.
May your cursor always snap to the location intended.
en respuesta a: SEANT61
SIR!!!!!  Thank you! You have saved my life.
Thank thank thank you. :cara_que_ríe_con_la_boca_abierta_y_los_ojos_sonrientes:
i aslo have a problem with my dxf file can u plz help me get my file back:  DXF read error on line 458023.
Alfred.NESWADBA
welcome @Anonymous.autodesk.com!
Open the DXF in an editor like notepad++, goto line 458023 and try to repair it.
If you want that we take a look into it the file would be necessary then.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
en respuesta a: Alfred.NESWADBA
i have a problem with dxf file :
Heres the info
Alfred.NESWADBA
the file is defect in a way I guess it's not repairable. Even if your play with the end-of file settings I guess there would be parts missing.
Reason I think: a download of that file (or any transfer) has lost the end of the file as it is nulled out.
Try to get the file again from the sender.
- alfred -
Alfred NESWADBA
Alfred.NESWADBA
find attached a file, which is the maximum of what I can get from that DXF (no warranty at all).
- alfred -
Alfred NESWADBA
okk thanks for ur help
bahaa.moghraby
hello
I was having the same problem and I fixed it using different software like Pro-E
Please help me I am having the same problem.
Alfred.NESWADBA
please find the repaired file attached (without warranty about correct content)
- alfred -
Alfred NESWADBA
Thank you very much, can you please help me to save it in 2010 version?
Alfred.NESWADBA
Please find attached the file converted to 2010.
- alfred -
Alfred NESWADBA
Thank you so much for the help, the drawing has opened!
I have the same problem with my file. Where and how should I send you my file?
Alfred.NESWADBA
You can upload it here to the thread...
What does AutoCAD show when you try to open (or insert) that file?
Which version of AutoCAD do you have?
- alfred -
Alfred NESWADBA
My name is Alexander Slag and my problem stands below by opening file i get a error. :cara_con_los_ojos_en_blanco:
Autocad version 2016
dxf Error by opening file.
BLOCK_RECORD Table Invalid symbol table record name: "" on line 7476.
I hope you can help white te problem i have also have a problem to attach the files to te mail.
Correct the highlighted errors and try again.
The attachment's ejb15a.dxf content type (application/x-dxf) does not match its file extension and has been removed.
The attachment's ejb20a.dxf content type (application/x-dxf) does not match its file extension and has been removed.
With kind regards,
Alexander Slag
Traverse_Stainless_and_Millwork
I see that the files have been repaired and sent back, but what is the repair process?
compare both ascii files (the dxf are textfiles).
Powerful Texteditors can compare them.
But why you are asking, is it your file?
Other files & repair processes won't help you with other files.
The general process is to check the issue and to correct the .dxf file manually.
One exception: Some issues are ignored by some other software what can read .dxf files, so it is possible to open and save a dxf by a non-Autodesk software.
Sebastian
