elshawadfy
en respuesta a: Anonymous
Hi @Anonymous,
If I understand wright, you created a custom block with geometries and attributes on a layer different than 0, and their properties are set to by layer instead of byblock, and used the block in multileader style.. you found out that the geometries took the proprties of their original layers but the attributes didn't..
If that's wright, then although the attributes in the leader block don't take on the appearance of the layer they reside in like the rest of the block, they still reside on that layer.. so if you turn it of they will be turned off as well..
Good luck :cara_con_una_leve_sonrisa:
