john.vellek
en respuesta a: Anonymous
Hi @Anonymous,
It looks like you have an interesting challenge ahead of you. Your migration will not likely see any corruption if you have a solid Internet connection but I would be careful to make sure that you have policies and practices developed and documented before you do this procedure. Have you been using a Local Sharepoint database to do this until now? If not, I would certainly run a pilot to make sure that file transfer speed, xref paths, recoverability , etc. are all taken into account before moving everything to the cloud.
Since AutoCAD saves the entire file and not synchronizing at a bit level you will see quite a bit of bandwidth being taken up.
Please see this prior post for some more insight.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
