1344 Vistas, 12 Respuestas
Layout tabs won't open in 3D model AutoCAD 2016
We have an AutoCad 2016 file created with a 3D model & various detail paperlayout tabs.
When i try to load into an ealier version it will open the file but not allow me to change to some of the tabs. it just gives the timer wheel.
i have left on for 24 hours to see if it would kick in but it just hangs there.
I have tried creating a W-Block, Auditing & Purging but nothing seems to have any effect.
when checking the file after its loaded i do have a lot of modelling operation error, unknown surface type in make silhouettes.
and this is a trusteddwg file.
we have to submit to our clients in 2014 format, but if they can't open the file will cause problems for us.
@Anonymous,
john.vellek has edited your subject line for clarity:File Access
Etiquetas (1)
en respuesta a: Anonymous
You'll most likely need to post your dwg for real assistance.
TheCADnoob
you can try using enablers if you know the verticals used to create the file.
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/ENU/123112/fil...
Also you can try opening it in a platform that doesn't have errors and try -EXPORTTOAUTOCAD
CADnoob
TheCADnoob
en respuesta a: TheCADnoob
i might try saving it to a previous version as well just to see if it makes a difference.
CADnoob
john.vellek
Hi @Anonymous,
Can you tell me what is on the Layout tabs? (or better yet attach a sample drawing) If the detail views are created using Viewbase that will be totally different than if you just have viewport views of your model.
John Vellek
john.vellek
Hi bhancock, I was hoping to see an update on your post.
I look forward to helping you figure out this issue.
John Vellek
en respuesta a: john.vellek
We are just using the basic package of autocad.
the layout tabs only have viewports
i have managed to get over it by copy and pasting the model into a fresh drawing then pulling in new tabs from the corrupt file.
this has worked but obviously i am losing any associativity to the model.
regards
wispoxy
Change your workspace to 3D Modeling or 3D Basics.
elshawadfy
Hi @Anonymous,
I'm afraid I don't have a solution, just a diagnosis..
I suspect the layouts that didn't open are the ones where you used ViewBase and related commands..
Unfourtunately the views created in later releases with this command are not compatible with earlier releases..
I also think that importing the layouts severs the link to the command and the views become just blocks, thats why you were able to import them, and the assossiativity was broken as you said..
john.vellek
en respuesta a: elshawadfy
Hi @elshawadfy,
This indeed sounds like it might be the case. I hope that @Anonymous can confirm this by marking your post as the Accepted Solution.
I am also reaching out to our team to see if the documentation can be improved regarding the Inventor piece and backward compatibility issues.
Thanks for your contributions.
John Vellek
wispoxy
I had an issue with layout tabs never opening, but that was because of an XREF, not the viewports. When I detached or removed the XREF(S) I was able to open the tab.
elshawadfy
@john.vellek wrote:
Hi @elshawadfy,
Hi @john.vellek, don't mention it :cara_con_una_leve_sonrisa: I'm glad I could help :cara_con_una_leve_sonrisa:
Good luck..
en respuesta a: wispoxy
There are no external references attached. so nothing to remove.
regards
