agodwin444
250 Vistas, 1 Respuesta
AutoCAD 2016 Failed Installation
I have been trying to install a student license version of Autocad2016 onto my windows 10 machine and am recieving the same error each time I try. I have saved a copy of the log file and also attached a screen shot of the error that comes up each time. It stops part way through downloading install files for some reason.
I had a similar issue trying to install Inventor Pro 2016 but after mutiple attempts and computer restarts it just installed successfully eventually.
I have ensured all of the windows updates are done.
I would appreciate any suggestions you may be able to offer.
Alfred.NESWADBA
en respuesta a: agodwin444
welcome @forums.autodesk.com!
The last two lines of the log file contain:
  • Download Failed, Installation aborted, Result=1603
  • DirectX Runtime    Failed    Failure is ignored, Result=1619
So the best would be to search for "AutoCAD installation 1603 1619" and you'll find a lot of suggestions, articles and solutions >>>click<<<
Good luck, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
