caprousalis
10977 Vistas, 38 Respuestas
Cannot enable hardware acceleration Autocad 2015
Interesting problem. I have two workstations and both seem to have the same problem. Recently (it used to work on both after initial install) I cannot view
point clouds (boxes appear with text that basically say "point clouds are not displayed when hardware accelleration is off"). Problem is I can't enable hardware acelleration (greyed out). Related hardware: MSI GT70 (I7-4940mx, Nvidia GTX880m) also Dell Precision T1700 (Xeon E3-1270, Nvidia K4000). Both have the latest video drivers. I rolled back the driver on the desktop to the earlier certified driver with no effect. About to pull my hair out on this one. Is it a driver issue or an update from windows. Should I have completely uninstalled the current drivers and then install the older "certified" drivers? The K4000 is certified by Autodesk so I feel confident this isn't a hardware issue. Not sure when the problem first appeared because I work mostly with Faro Scene software (laser scanner) and only occasionally import point clouds (via Recap) into Autocad. Any help would be much appreciated. -cp
