ROBIELITCHFIELD1568
602 Vistas, 5 Respuestas
trying to do a hatch
Hello - I am trying to non-associative hatch an object and am getting this message
Proxy metafile contains bounding box. Not exploded
how do I make this go away?
Robie
does >>>this thread<<< show the solution for you too?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Hi and Welcome to AutoDesk Forum,
I think that there is a proxy object that is part of your hatch boundary,and this proxy object usually come from another AutoCAD software.
So my advice for you is to draw a polyline for the area you want to hatch and isolate it (Layiso) and do your hatch without any problem. OR you have to explode all blocks that done these message and i think that not a solution.
Good Luck..
Imad Habash
Hi ROBIELITCHFIELD1568,
I am checking back to see if posts in this thread helped you with your problem. Please add a post with your results so other Forum users can benefit.
It does indeed sound like you have some proxy objects that you need to consider. If you would care to attach your drawing to this thread I am happy to take a look at it for you.
Please hit the Accept as Solution button if a post or posts fully solved your issue or answered your question.
John Vellek
I was able to fix this by installing object enablers for Civil 3D - the other solutions did not work.
no - i needed to install object enablers for Civil 3D - works like a charm now.
