05-31-2016
08:57 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
05-31-2016
08:57 AM
Its hard to tell from the screen shot but it looks like you are going to have to clean up your drawing first. It looks like some lines are extending past others. If this is the case there may be other issues as well. All lines will need to be ended at the "vertex" of the other lines.
Once that is done you can proceed as @rkmcswain suggested and join the lines into a poly line and then the offset can be don as one object as per the screen cast.
https://knowledge.autodesk.com/community/screencast/9d76669d-c6f1-495b-9f7c-43e3d1322044
CADnoob
