- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hey all,
I am currently learning AutoCAD as a student. I have an assignment that is easy to grasp, but I am having a challenge in execution. Basically, I have created the outline/permiter of a house floor plan. It is a complex polygon with bumpouts, and insets. My challenge lies in the task of creating a 4" inside wall offset from the perimiter. Please view my attachment for a view of what I am working on.
The drawing was created out of individual lines. I have no problem offsetting these. The issue lies in the fact that it is tedious and cumbersome to offset several dozen lines, and then have to tidy them up with trimming. I thought that a far easier way would be to convert the individual lines into a polygon by grouping them, and then offset the grouped object. I could not make this work for me. I then experimented with an irregular object, created from a rectangle with a mitered corner. I found that I could only offset this object if it was a polyline, and not grouped. Here are some issues that are baffling to me:
- Does 'grouping' create a polygon?
- If I have a polygon, how do I change it to a polyline?
- Why am I able to offset a polyline object, but not an irregular object created by grouping lines?
- What is an efficient approach to my challenge, if my solution is sub-optimal?
Many thanks to all for any suggestions ...
¡Resuelto! Ir a solución.
