ВeekeeCZ
en respuesta a: Anonymous
@Anonymous wrote:
Can anyone tell me how to get a Layout tab with a Viewport that has a layer state that is different from any of the other layout tab or model tab, and stays that way.  That doesn't change when I change the layer state in the model tab??? or one of the other layouts?
Main thing you should focus on is "Apply properties as viewport overrides." Is important to have this ON when you apply saved layer state on a layout.
It doeš not matter that much if you have this created in model or layout space (unless you did assign VP properties - right columns in layout layer properties dialog, which you did not).
BTW you cannot assing some specific Layer State to same specific Layout. This is just one-time thing, no other layout-NameState relationship.
Space column - is where this was originally saved (difference if you assigned VP properties).
Same as DWG - there are no VP properties, so it would be the same result no matter whether you apply this in model or layout.
HTH
