imadHabash
en respuesta a: Anonymous
you can reach for a good results by using layer manager after clicking through viewports itself (see attached image) which you can change all tabs starting with VP this will distinguish all of your Lauouts viewports with notice that your MODEL will not be changed.
SO ... click through VP then use Layer Manger to change as your need . also if you have alot of drawings you can use Layer States Manager to save all of your changes.
I hope it's help .... Good Luck
Imad Habash
