Alfred.NESWADBA
en respuesta a: Anonymous
>> a coworker also using these drawings with 2015, he does not have the same issues as me
Which issues do you have? Just to see the message that an objects enabler might be installed is not an issue, that might be a different setting of PROXYNOTICE or your coworker may have AutoCAD Architecture or AutoCAD MEP?
>> Is there a way I can check to see if the object enabler is working/installed/enabled
If it is installed it works (by default).
I have not verified that, just an idea (as long as you are really sure about you and your coworker do have the same product): load this drawing that brings up the proxy-notice-dialog, then start command _APPLOAD and compare the list of loaded applications (compare the DBX files) with the same list from your coworker.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
