05-24-2016
06:54 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
05-24-2016
06:54 AM
>> I have downloaded the plugin
How did you download it (using which software) and how is the file named you have downloaded? If it's just an EXE file or an MSI file then you have to double click it to get installed.
If it's installed or not can only be seen within the Windows control panel ==> programs and functions.
>> When I load the project it is not listed under the addin tab.
The object enabler does not have any commands, so it is not listed anywhere within AutoCAD as "real" apps are.
It just loaded and hidden and gets active when you open drawings with objects from ACA/MEP.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Alfred NESWADBA
