ali.derman
444 Vistas, 1 Respuesta
Plot Custom Properties Error
I have Autocad 2013-2015 products. When plot on drawing, I select my printer and than printer custom settings , Autocad products give fatal error and closing.
I use windows 10 Pro 64-bit operating system.  I attached error screen shot.
I look forward to hearing solution from you as soon as possible.
Sincerely,
Ali Osman DERMAN
Alfred.NESWADBA
en respuesta a: ali.derman
HP does not provide drivers for the 10xx plotters for Windows 10 and AutoCAD seems to have issues using this drivers (>>>discussed here<<<)
You'll probably have to create a PC3 using the HP DesignJet 755 (or a global HPGL2 plotter) using the "add a plotter wizard" within PLOTTERMANAGER.
Be careful, the colors might differ.
Sorry, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
