john.vellek
en respuesta a: francoise.k
Hello francoise.k,
There are a lot of posts regarding your issue but I haven't seen an update from you. I would like to make sure that your issue has been fixed.
Is this happening on all drawings?
Can you start AutoCAD (version?) with a new drawing? If so, when you save the new drawing, close it, can you reopen it without any problems?
If that works then perhaps try a RECOVER on one of the existing files to see if that helps. Audit and Purge are good tools to run frequently as well.
Please also try disabling all graphics hardware acceleration options.
One last thing to check is to see which page setup has been applied to layouts within the drawing(s). It is possible that the printer configuration is corrupt (PC3).
Please update your post so I can continue to assist you.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
