TravisNave
en respuesta a: Anonymous
Install	Autodesk Material Library 2017	Failed	Download Failed, Installation aborted, Result=1603
It's a download failure.
If you are having problems downloading your 2017 software from your Autodesk Accounts page or from the Trial/Educational version, then please see this list of downloads provided here:
http://forums.autodesk.com/t5/installation-licensing/community-downloads/td-p/6314550
Good Luck!
Autodesk Forums:
