Hi @ryan-lehtonen,
Thank you for joining us for Answer Day!
For tools that you are adding to a tool palette (a block tool, for example), the default General Properties should already be set to "By Layer", if you drag the block from the open, saved drawing onto the tool palette.
Is this not what you are experiencing?
There is also a bit more information about the procedures for modifying tools here, which covers the process available for applying property overrides. As far as I can tell, there isn't a way to automatically apply custom overrides to each tool you create.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
