362 Vistas, 3 Respuestas
aligning text independently
I'm working with a CAD floorplan that shows room numbers and I need to show the square footage of each room below.  I'm using MTEXT to show each room number and square footage, each on their own respective layers.  I was wondering if there is an easy way to align the square footage under the room number with uniform spacing.  I tried using the TEXTALIGN command, but that just lines up each MTEXT along a single line, and evenly distributes them.  Since the rooms vary with the positions, I need to have each square footage MTEXT align underneath a respective room number.
Thanks.
Etiquetas (1)
john.vellek
en respuesta a: Anonymous
Hi stcampi4 and Welcome to the Forums!
I suggest a better way to accommodate this would be to use Attributes in a block to create your room labels and area tags. Each attribute can still be on a unique layer.
I have attached a sample block so you can try it out.
The nice feature about having it in a block is the text is always aligned properly and you can also data extract the information into a table or schedule if you need to.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
Going with blocks is the ideal situation as John pointed out.
If you can't do this you could use a LISP that set the MTEXT to some type of CENTER justification and then matched the position based on rotation/location.
But a block would be so much easier...
john.vellek
Hi stcampi4,
I am checking back to see if my post helped you with your problem. Please add a post with your results so other Forum users can benefit.
John Vellek
