05-18-2016
06:39 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
05-18-2016
06:39 AM
Hi nadav,
if you make an offset e.g. from a circle the offset of this circle will be save as a circle as well in the dxf-file.
The difference between code 5 and 330, you can read here: http://www.autodesk.com/techpubs/autocad/acadr14/dxf/group_codes_in_numerical_order_al_u05_c.htm
5 is an entity handle in general to handle the objects in the drawing
330 is a soft-handler to handle blocks and xrefs in a drawing.
For the last question about the polygon split: Can you explain me a scenario what you are mentioning here exactly?
Thank you
Bernd
Bernd G.
Senior Product Support Specialist
