1071 Vistas, 3 Respuestas
05-18-2016
06:17 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
05-18-2016
06:17 AM
Hello autocad developers!
how does the Autocad make an offset in the DXF file?
Meaning there are many kinds of offsets (with radii or without etc.).
How does it work? How do you know when to split a polygon? What is the algorithm?
In addition, in the DXF file, in the entities section.
What is the difference between code 5 and code 330?
Code 5 is different for each entity? Also code 330?
What does code 5 has to include? Can it be only letters? Only numbers? etc.?
Example of a circle code:
0 SECTION 2 ENTITIES 0 CIRCLE 5 75F 330 1F 100 AcDbEntity 8 0 100 AcDbCircle 10 0.0 20 0.0 30 0.0 40 1.0
Code 5: 75F
Code 330: 1F
Seems like the DXF must have those codes. What are the rules for them?
Using Autocad 2013 and up
¡Resuelto! Ir a solución.
