368 Vistas, 2 Respuestas
pdf to dwg converter
hi everyone.. who has pdf to dwg converter here?? I badly need it right now.. I really appreciate ur help!
Thanks in advance!
TheCADnoob
en respuesta a: Anonymous
Assuming you have a vector PDF this is avaliable nativley in autocad 2017 using import.
http://blogs.autodesk.com/autocad/autocad-2017-pdf-import/
CADnoob
john.vellek
Hi @Anonymous,
What version of AutoCAD are you using? As @TheCADnoob posted, AutoCAD 2017 has built in features that will help you to convert vector-based PDF files into AutoCAD native elements. Here is an AKN Article that explains the features.
Please post your results here to benefit others.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
