05-16-2016
12:35 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
05-16-2016
12:35 AM
welcome @forums.autodesk.com!
>> Can autocad edit pdf file after using import PDF function
You can import the PDF-content and then edit the content, but the imported geometry are then AutoCAD objects, not any more PDF objects.
However, when you finished the modification you can run _PLOT and create a new PDF file from that.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Alfred NESWADBA
