en respuesta a: stevetamplen
Yes, this is completely possible using live sections.
First, create a live section plane using the SECTION PLANE tool under home (3D Modeling Home).
Second, select the live section and change the visibility setting to SLICE.
Lastly, while the live section is selected your ribbon will allow you to change the slice thickness under the ADJUST panel.
Thanks.
Etiquetas (1)
