jggerth
en respuesta a: Anonymous
Possible things to try -- AUDIT and PURGE all the Xref files before trying to eTransmit your final drawing.
Can you manually Bind the xref?
There may be AEC objects from verticals that have infested your Xref dwgs.  If that's the case, you may need to export the Xref drawings to vanilla before binding will work.
