stevetamplen
en respuesta a: Phil
Hello Phil;
Although I am no expert in Revit, once you have the design there, you should not need to return to AutoCAD.
As far as doing the work in vanilla AutoCAD, you should be able to use 3D Clip and Section Planes to accomplish your stated goal. That having been said, it would probably be much easier to do that work in Advanced Steel.
I hope that helps.
Steve Tamplen
Technical Support Specialist
