2618 Vistas, 1 Respuesta
Display on Surface Pro 4
Hi all,
I was using Surface Pro 4 i7 as I had to travel a lot for businees need. I've installed the latest updates of AutoCAD 2017 but still got the problem of display. As the definition of Surface is very high at such 11.7 inch size, the fonts were scaled as 200% as normal by Win10 system. On Version 2017 of CAD, better than 2016, the ribbon tool pannel display is fine. But the tool boxes used floating on the edit area is still been scaled the fonts. So the display is really bad. With very small (maybe original size of icons) icons but large large fonts. Could anybody have some configuration solution on this?
Etiquetas (3)
TheCADnoob
en respuesta a: Anonymous
You will have to bring your resolutoin below 2000 in both directions
http://forums.autodesk.com/t5/autocad-2013-2014-2015-2016-2017/properties-menu-appear-larger/td-p/62...
Help autocad with feeback on this issue with this survey:
http://forums.autodesk.com/t5/autocad-2013-2014-2015-2016-2017/screen-resolution-text-size/m-p/62296...
CADnoob
