kennyj
en respuesta a: Anonymous
Hello Bruce4444, Several options here: 1) use layers for types; if you have boundaries for areas (Polylines) then put them on a layer so you can select by layer. 2) Use the filter command; select, filter and chose lines vs polylines 3) You can cycle through the objects that lay on top of each other. Here is a link to an article on doing this since the way to cycle depends on your version of the software: https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to... Hope that helps! Kenny
