en respuesta a: Anonymous
I have the same problem with autocad 2015 and 2017. I haven't tried out in 2016. It works fine in autocad 2014. Autocad 2015 and 2017 displays error message- "Flatshot operation did not produce any geometry. It happened in the 3d models with non uniform scaling. I tried flatshot on simple cube. It worked in autocad 2017. So, the problem is with the non uniformly scaled 3d blocks. However, flatshot works with non-uniformly scaled 3d blocks in autocad 2014 but produce flatshot of original size( not the scaled one).
