- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Just tried with LT 2017. Works after deleting /language "eng-US".
Tried Reset Settings to Default - same two errors again... ![]()
Hope there will be fixes soon. Want work in 2017, but its no possible. Crashing on first start is no only bug, there is problems with copying from file to file. I don’t know, is copying crash in Eng-US Windows 10 or not.
Edited by
Discussion_Admin
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
You should be able to leave the /language "eng-US" off for the time being so you can use the product without the error.
I am using mine without the language switch and it works fine.
Can you please tell me what you mean by the statement "there is problems with copying from file to file"?
Is this related to the problem we are discussing, or something different?
Steve Tamplen
Technical Support Specialist
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
In AutoCAD LT 2017, when I copy drawings from another file, then paste in my file, error occurs. Not in all cases. I have noticed that it is more common happen when I paste objects with hatch. I sent generated error reports to Autodesk. These errors are similar to errors on first start, always two errors at one time.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
There is new update - hotfix 2. Just installed, tested... No more problems. 2017 works fine. THANK YOU, AUTODESK. ![]()
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
