RockyBrown4134
en respuesta a: scot-65
@scot-65 wrote:
And another trick...
Have the image loaded into the clipboard.
Use the Paste Special (as "Device Independent Bitmap") inside the Edit menu and paste to a blank drawing.
Save that drawing.
Insert the file that has the image into the desired destination file and leave intact as a block.
You can now rotate, scale, mirror, etc. as you see fit...
(I do this with certain uncooperative PDF's as well)
I must be doing something wrong. I tried the steps you indicated four times, I still get a block with the image remaining horizontal no matter what angle I rotate the block (wblock). I put two blocks in a another new drawing, and rotated the two about the same base point. the frames rotated correctly, however the image remained horizontal.
If this response answers your question, Please mark this response as "Accept as Solution"
Rocky Brown
AutoCAD 2020 / Inventor 2020 / Plant 3D
