scot-65
en respuesta a: RockyBrown4134
And another trick...
Have the image loaded into the clipboard.
Use the Paste Special (as "Device Independent Bitmap") inside the Edit menu and paste to a blank drawing.
Save that drawing.
Insert the file that has the image into the desired destination file and leave intact as a block.
You can now rotate, scale, mirror, etc. as you see fit...
(I do this with certain uncooperative PDF's as well)
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
