john.vellek
en respuesta a: RockyBrown4134
Hi @RockyBrown4134,
If you select an Xref in the External References manager, then you can rt-click on it and select Bind. You will then have the option to Bind or Insert.
I have gone back to 2013, 2014, and 2015 versions of AutoCAD and I do not see that binding an image has ever been an option. If you open your image in an editor such as Paint, select all and copy, then you can paste into your drawing as a BMP format. This image should be embedded in your drawing.
Depending on the image, it might be worth taking the time to convert it to a vector format. Check out Vectorize It from Autodesk as one option.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
