Kent1Cooper
en respuesta a: Anonymous
If I understand the problem correctly, you want to change the color of Mtext content even if it has an internal color assignment [the {\C2 is what makes it yellow].  If you want to assign the color to the Mtext object as a whole [as would appear in the Properties box], and avoid having to edit away the internal color manually, you would need something that will remove the internal color assignment.  Search for a routine called STRIPMTEXT by Steve Doman and Joe Burke, which can remove internal overrides like that, so that a color assignment from "outside" will work.
Kent Cooper, AIA
