474 Vistas, 5 Respuestas
Mtext replace color
dear all,
i need to change the color of mtext. i can not predict the mtext in which format. some of the mtext can change the color, some of the mtext can not change the color. but the formated mtext can change the color when we edit the text by double click. so please help me. BELOW I HAVE ATTACHE A PPT IMAGE FOR YOUR REFERENCE. PLEASE SEE THE PROPERTIES MD ROOM WORD.
TheCADnoob
en respuesta a: Anonymous
Please only post your problem once.
CADnoob
TheCADnoob
in PAGESETUP is your display plot styles enabled?
CADnoob
en respuesta a: TheCADnoob
YOU DO NOT UNDERSTAND MY  PROBLEM...
TheCADnoob
help me understand. Could you show your problem to me using a screen cast?
http://www.autodesk.com/products/screencast/overview
CADnoob
Kent1Cooper
If I understand the problem correctly, you want to change the color of Mtext content even if it has an internal color assignment [the {\C2 is what makes it yellow].  If you want to assign the color to the Mtext object as a whole [as would appear in the Properties box], and avoid having to edit away the internal color manually, you would need something that will remove the internal color assignment.  Search for a routine called STRIPMTEXT by Steve Doman and Joe Burke, which can remove internal overrides like that, so that a color assignment from "outside" will work.
Kent Cooper, AIA
