1127 Vistas, 3 Respuestas
How to add a hatch pattern at 90 degrees?
Am using Autocad 2016.
How can one add a hatch pattern at 90 degrees?
Thank you for your help.
Kent1Cooper
en respuesta a: Anonymous
Rotation angle is one of the standard choices in Hatching [here from AutoCAD 2016]:
Or, done by command-line prompts instead:
Command:  -HATCH
Current hatch pattern:  ANSI31
Specify internal point or [Properties/Se....sparency]: P
Enter a pattern name or [?/Solid/User defined/Gradient] <ANSI31>:
Specify a scale for the pattern <1.0000>:
Specify an angle for the pattern <0d0'0">: 90
Specify internal point or ....
Kent Cooper, AIA
scot-65
Programmatically:
(setvar "HPANG" ang) ;where ang is in radians
For your request it is (/ pi 2.0)
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
en respuesta a: Kent1Cooper
Thank you.
