en respuesta a: JDMather
Many thanks for your reply.
I have changed the units to mm.
I require the barrel to be a mesh in my simulation and the screws to be solid.
I do have autocad inventor, I tried to convert the mesh to stl using this and I am also unable to. Maybe becuase I have not used it a lot. Can you give me basic instructions how I can use inventor to convert the mesh to stl file.
Since I will be using Autocad for the screws and Inventor for the mesh, would I come across problems that I was having earlier in terms of alignment and orientation etc?
Thanks in advance for your assistance.
