JDMather
en respuesta a: Anonymous
Your document units (accessed with command -dwgunits with the preceeding - sign) indicate that you are working in inches.
Your parts are not likely to print to the correct size.
Are you a student?
If so, why are you using AutoCAD for this design rather than Autodesk Inventor.  (Students can get Inventor for free here.)
You might try Thicken of your surfaces into solids.
Is there a reason you did not create the Barrel as a solid to begin with?
