04-26-2016
01:26 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
04-26-2016
01:26 PM
What are the intended units for your geometry (it is tiny)?
When creating solid models you should have delobj variable set to 0 (off) and put the generating geometry on a hidden layer.
If you had done this - you could use the axis of revolution/helix to align the parts.
Are the two screws the same, or are they different?
You should create your geometry with logical reference to 0,0,0 and the X,Y or Z axis (Cartesian Coordinate System).
If I create a line starting at absolute (0,0,0) it should be the axis of your screw.
(preferably with the axis on Z)
