en respuesta a: DanielkrampenV8756
@DanielkrampenV8756 wrote:
Thanks in advance to everyone for your help. I am using autocad 2016. I am attempting to show a dim angle at greater than 180 degrees. I understand the way to do this is to select the vertex and then select the end points. When I select dim angular it doesn't allow me to select the vertex. Is there something special I need selected under snaps or something? Thanks again.
Post your dwg.
