Alfred.NESWADBA
en respuesta a: Anonymous
even if that is not the best solution, but at least an option to continue to work :cara_guiñando_un_ojo:
Within the material-editor ==> texture editor you can enter the units now into the position and scale settings, so in case you enter the value including the untit-shortcut:
1000m
it accepts really 1000 Meter, just the display changes it back to inches and shows then 39370,08in
The good point on that: you can enter 1000m, the bad on that is if you just want to check the value you have to convert the units.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
