en respuesta a:
02:42 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
04-25-2016
02:42 PM
I toggle between world UCS and PLAN UCS in every drawing. If I lay out text
with MTEXT command, then edit, the text editor stays with its original
alignment. If I open a drawing from my co-worker, then edit his text in the
MTEXT EDITOR, the selected text rotates to its original cardinal direction;
east, west north, etc., then rotates back to normal alignment. There must
be a setting as this has been the case from version 2010 to present 2016.
If I match properties from mtext I have created to his text, then the text
stays aligned (horizontal) to its original direction. The same is true in
the Properties manager. If I am in PLAN and select the alignment to east it
rotates to screen east, but his text rotates to world east. Thanks, this
problem has troubled me for over a year now. Even after upgrading to new
software AUTOCAD CIVIL 3D 2016 and Carlson 2016
* Richard Taylor,RPLS TX #3986Survey ManagerRichard@ashandassociates.net
P:(512) 392-1719F:(512) 392-1928132 Jackson
Ln.San Marcos, Tx 78666[image: ashMailsign]www.AshandAssociates.net
