1328 Vistas, 7 Respuestas
MTEXT EDITOR SKEWS TEXT DURING EDIT
WHEN EDITING TEXT IN MTEXT EDITOR, TEXT SKEWS DURING EDIT, THEN RETURNS TO ORIGINAL ALIGNMENT
john.vellek
en respuesta a: Anonymous
Hi Richard,
Welcome to the Commnuity Forums!
I am sorry that you are having problems with MTEXT. Can you please tell me if you are working in modelspace or in paperspace when this happens? Are you working through a viewport or are you working directly on the model?
I look forward to helping you with the problem.
John Vellek
I toggle between world UCS and PLAN UCS in every drawing. If I lay out text
with MTEXT command, then edit, the text editor stays with its original
alignment. If I open a drawing from my co-worker, then edit his text in the
MTEXT EDITOR, the selected text rotates to its original cardinal direction;
east, west north, etc., then rotates back to normal alignment. There must
be a setting as this has been the case from version 2010 to present 2016.
If I match properties from mtext I have created to his text, then the text
stays aligned (horizontal) to its original direction. The same is true in
the Properties manager. If I am in PLAN and select the alignment to east it
rotates to screen east, but his text rotates to world east. Thanks, this
problem has troubled me for over a year now. Even after upgrading to new
software AUTOCAD CIVIL 3D 2016 and Carlson 2016
* Richard Taylor,RPLS TX #3986Survey ManagerRichard@ashandassociates.net
P:(512) 392-1719F:(512) 392-1928132 Jackson
Ln.San Marcos, Tx 78666[image: ashMailsign]www.AshandAssociates.net
john.vellek
Hi richard,
I haven't seen this issue before. Let me do a little digging. In the mean time, can you send me a drawing file or two that displays this behavior?
John Vellek
TheCADnoob
MTEXTFIXED may help though im not sure if this is your problem. I have read that using certain fonts can have this behavior. If you are using a font that has other alternatives like 'Sans' or 'unicode sand MS' try switching those around and see if it makes a difference.
CADnoob
en respuesta a: TheCADnoob
Thanks, here is example of two paragraphs in MTEXT, the upper paragraph behaves normally, but lower skews when edited as shownACAD SCREEN SHOT.jpg
pendean
It's rotated the same angle as your UCS it does that.
