04-25-2016
12:55 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
04-25-2016
12:55 PM
Usually the last thing you draw (or insert) is on top unless you have something helping it get pushed to the back. True for AutoCAD2014 and higher and lower.
Yes, this is the issue I'm trying to fix. There has to be a system default for this.
Is there perhaps a Z-drection settings not being observed in the file(s)? OSNAPZ variable in effect perhaps? Does REGEN or REGENALL fix the display and thus allow you to select your newly drawn object?
None of these fix the problem.
How would DRAWORDER not apply: wouldn't it move the object you don't want from the top to the back?
Draw order defeats the purpose of having a default that puts the last draw line on top of the "traced" lines.
