- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I have always been able to draw (or trace) a pline over an existing object and then be able to select that line.
Similarly when creating a boundary set, and the resulting p-line is by default on top of the "old" set of lines. Simply click on the new boundary and you are good to go.
Somehow the selection feature has been changed so the new lines are sent behind previously drawn lines. This is getting very frustrating. I can use move/last but I should have to.
I’m not sure if this is a system setting or not.
I don’t think Draw Order is the answer, as this just moves lines.
I am using AutoCAD 2014, installed on my computer by the IT guy.
Any help would be appreciated.
Chris
¡Resuelto! Ir a solución.
