457 Vistas, 3 Respuestas
AutoCAD opens but i cant create anything
Hallo,i downloaded the  AutoCAD 2017 demo version about 2 weeks go. Everything was running perfectly until 2 days ago when i open autocad the main screen where you draw crushes but the rest is fine. Has anyone had something similar happend to him. Any tips to take it back to normal?
thank you for your time!
pendean
en respuesta a: Anonymous
Use RECOVER command to open the dwg file and see if the problem is a corrupt drawing.
If the file has Xrefs use RECOVERALL command instead.
en respuesta a: pendean
thank you for your help but still nothing. Even when i open a new one to start from scratch, the main area is crushed and i can do anything
Unbenannt.PNG     i got it back on working, i disabled the the option which you can find down right ( picture ). I can see the plans now.
