john.vellek
en respuesta a: brentcole3410
HI @brentcole3410,
Without opening your files, I suggest the next step is to continue with the empty template and start adding properties one at a time and verify that everything works properly at each increment.
I agree with @dbroad that this LSP file can not be helping things. It really does hijack the process away from the sheet set which is not good.
There is no easy solution to preventing users from moving things around. Instruction, policies, and procedures are usually the best in my opinion.
Please post your results as you build up your template so other users can benefit.
I will take a look at your files but I think regardless of my findings, that you will need to proceed with the above process as well.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
