brentcole3410
en respuesta a: john.vellek
I recreated a smaller sample model.  I tried what you recommended with a blank acad.dwt template and it seemed to work properly.  I do not quite understand why because our templates were originally generated from a slightly customized acad.dwt.  The only physical difference I see is our template has objects and layers.
I zipped and attached a sample sheet set with sheets, views and models.
